No change in the compositer
Hi, got to the composite stage but it doesn't change anything. I've tried multiple nodes but it doesn't change the render / image? any ideas please?
thanks
https://imgur.com/a/vdcjAHo
Reply
    You need to connect the fogglow. To the viewer node as well so that you can see the effect of the node. Also try a mix of less than 0.99 because 1 will always be black unless you add emission.
  • Omar Domenech replied
    Yes, same, adjust the mix value and connect the node to the viewer node in order for the previz to work.
  • Adrian Bellworthy replied
    And Yes, same. Notice the fog glow mix in the course is 0.00
